went ahead and cut up the center tunnel cover... similar to Desert S's but without added tabs, I'll likely highlight where the cuts are with more of the trim pieces akin to what DF provides for the front of the cover.
Ordered some things from amazon to streamline a few processes
Tygon 2375 Clear Hose 1/4" 6.35mm ID (Enough for all three connections at the reservoir)
3 Prong Plug Pigtail Harness for Tail Light
as well as the DF rear brake hoses for the frame to caliper connection
DF store - Braided Brake Hoses (rear only)
In The Meantime.... I'm playing around with the lighting and have the headlights as well as the side mirrors figured out for the most part
just have to decide on if I am going to simply use butt connectors or source proper plugs to match the side mirrors.
I have the head light harness from the donor for both sides, and worked in a plug connection for the headlights.
I still have an empty socket for the side marker lights and hope to save that for adding lighting to a front spoiler.
The brake handle is also being installed as I have the cables running and the tubing is in place on the sub-frame.
the rear section of the tunnel cap will need to be drilled out for the bolts and the handle will be straddled by both shifter cables on either side. I hate to admit that I should have waited to put the firewall in place until AFTER i installed the brake and shifter, but hidnsight is 20/20.
EDIT: realized after the fact I should clarify on the electrical wiring situation... will post what is connected where, with pics once i get home and can document properly.
Front
DF wiring [ solderd to ] stock headlight plug [connected to] donor headlight harness [solderd to ] custom plugs for lights
Rear
DF wiring [solderd to ] custom plugs for lights
