SmsDetroit
What size tires are those. Look greatMade it into the garage just long enough to put a arms on one side to test fit a wheel
I'm going to guess 275/40R17What size tires are those. Look great
Looks like the 3 bar map sensors. Common upgrade with a tune to get more HP out of the LNF.Pretty sure this is an intake air temp sensor and that it goes in pipe between throttle body and intercooler, but looks different than ones I've seen in other builds and hole doesn't line up?
Trying to confirm it does go here before I start making it fit. Thanks
Thank you hole is a little off, but close enough I can make it workLooks like the 3 bar map sensors. Common upgrade with a tune to get more HP out of the LNF.
Single bolt is fine. I believe that there is a 3d printed bracket that would help hold it in but plenty of people run just the one bolt with no issues.
Been driving mine for 2 weeks before I saw this post. Went back and looked at mine. Apparently I’ve been driving around with a vacuum leak.Been looking all over not sure where this line goes or if it just gets capped?
I don’t blame you. It looks great with those wheels on. How wide did you go?Going to have to take the wheels off to continue progress, since I test fit them all I do is stare at it and take pics.
