throwout bearing
ole mother
F35 trans brand new from Lonny.. The line that runs (from just inside the trans) to the throwout bearing is leaking.. Any fixes without removing entire motor trans etc.etc. Pull the plastic cover off trans and can watch it drip..
Missing o-ring or the throwout bearing has over extended and is leaking past the seal. O-ring is simple (relatively), the throwout bearing will require transmission removal. :(
And make sure you don’t have two o-rings in the elbow, one original and one from the new transmission. I had that problem.
