I didn't feel like I was able to get the tensioner to activate. I did a couple cold engine starts and definitely felt like I heard the chain rattle for the first 1-2 seconds. So I opened the valve cover back up and tried again. When I removed the tensioner this time, I absolutely heard it activate as I removed it from the engine block, so it never did extend correctly that time.
This time I followed the ZZP recommended install method.
Youtube link for ZZP video 4:30 in the video they talk about the install of the tensioner.
I did have to shove to get the threads started due to the activated length. Once installed I checked the slack on the chain to compare to the last image I uploaded, easily 2/3 of that slack was gone without rolling the engine at all. First startup was nice and quiet too, that chain rattle for the first 1-2 seconds is gone now.
Still used the zip tie method to hold the chain to the sprockets to maintain the timing setup. But I think it was way more straight forward to insert the tensioner already activated. Since the version I received can't just fall apart (used to be 2 separate parts sleeved together, new version is held together with a C-clip), I don't see why it would should only be activated after installation. Earlier versions sure, but not the current style I got.
