JeffsGoblin
Use lots of lube.... lots and lots of lube. I poured it directly into the tube and soaked the whole inside before putting it in. (No "The Office" remarks.)
I think Pink Panther is an excellent name for this rig!The pink panther lives! Great work and amazing how quickly you have been putting your Goblin together. Can't wait to see it finished.
Suppose I should stick to the instructions.Rear aluminum strut mounts are on wrong. They go under the steel mounts.
Thanks for the heads up and the pics! I'm a little disappointed I didnt know this. I'll try to knock that out tonight. I have a couple different tools to try.Now for the bad part. As I looked at your pictures things flash back to me. The bottom of the shift arm counterweight needs to be cut off It will not clear the frame rail when you put it in reverse. Before you get anything else in the way now is the time to do it ( well actually a lot earlier was the time) Tape up the frame rails beforehand. Here is an idea of how much you will have to cut off.
View attachment 13429 View attachment 13430
Everything on mine went over the top except for the heat exchanger tubes I just added. Just not enough room. If you look at top left of picture those are the shift cables.Question for the group, did you run your shifter cables over the front subframe member or under? Trying to decide how I want to secure them up. I went under, and I think I might swap around.
Where did you source your USB charger? Part #?Thanks for the picture Karter. I moved mine over and it makes way more sense.
Had a big setback today that I should have researched a bit more. The RPF1s hit the front calipers. Going to take the calipers to work and try to machine or grind them down.
Wish I would have found this two weeks earlier: http://dfkitcar.com/forum/index.php?threads/canyons-trackframe-lsj-t-htown.225/post-5647
On the upside, I got the drivers seat modified to fit. Still gotta weld the height adjustment, so it's springy now.
I have a USB charger that I'm going to mount in the tunnel cap somewhere like others have done. Found out the red wire I left in the tunnel isn't switched, so I'll have to add a switch or wire into the gauge panel switches. It's these final bits that take up all the time. I am dying to get it on the road!
You could do it how I'm doing it.Where did you source your USB charger? Part #?
