AleX1/9
I found a pretty great deal on an 07 SS supercharged donor after searching for several months on Copart, IAAI, and craigslist far and wide.
Catch is, car was wrecked in the front, and doesn't start with the key. The engine fires off great using a jumper wire on the starter relay pins underhood, but only runs for a few seconds, then shuts off. The fuel pump can be heard, all accessories turn on, and there is no security light on the dash. There is a check engine light and ABS light on the dash, but my OBD reader won't pick them up because the car isn't running.
What I've done so far:
-Checked all fuses with powerprobe, tested relay for starter, all fine.
-reprogrammed the key following instructions found online. Key on 10.5 mins, cycled 3 times with 45 second window. Tried twice, no result.
-Removed and cleaned all connectors on BCM, ECM, and fuse panels and major battery cable/fuse panel connections. Nothing suspect found.
-Disassembled column shrouding and inspected ignition switch connections and transponder ring, looks fine.
-tested clutch switch, ground in one pin at rest, ground on both pins with switch pushed in.
Items that are suspect:
-two sets of wires on the rear speaker shelf that are hacked off, shielded wires and twisted speaker wires tell they go to a factory amplifier/tuner that is missing. All speakers are missing, and there were amp wires strung around. Factory style radio in dash turns on. Not sure if this would affect the starting condition, but I do remember from my car stereo days that this era chevy requires a data wire module for aftermarket installation to provide an actual +12v ignition wire and in some cases door chime and other functions.
-Dash computer shows coolant temp at -40C and low coolant signals. don't think that's it either...
-Driver's side seat belt buckle will not release the belt... again weird but i don't think it's related...
-Unknown sensor found inside vehicle with one broken end (looks like maybe an ABS sensor?) It's about 3 feet long, has dark blue almost silocone like shielding, and small black 2 pin connector on the end. I'll have to post a pic...
My feeling is it has to be something simple like an inertia kill switch or bad key programming. Maybe a factory alarm? I don't have a fob for it. I did all the stupid stuff like add fuel in the tank, install fresh battery with charger, checked engine grounds, ETC...
You guys have any insight?
