tool list
I searched for a tool list and have not found one, yet. I know that the majority of the tools needed are normal, standard sizes. But, there are some outliers that I have come across already like - 35mm socket for my axle nut, fuel line connector release tool, T50 Torx socket, etc. I know some of the donor models may have slightly different requirements, but I would think there would be very few differences. Fortunately, I have been watching the videos ahead of actually doing them, so I was able to procure the odd size tools needed. Not sure if the majority of builders already have a roll around tool chest with every size tool imaginable. Unfortunately, I do not. :(
I would think it would be worthwhile if there were a list of tools (that are not simple wrench or socket sizes) that a builder could reference ahead of time. Heck, maybe even list the build video where the specific tool would be needed.
The ones needed for the Goblin assembly should be pretty easy.
Any thoughts?
@Adam @Lonnie
k.rollin
15/16 and 1-1/8 wrenches for the front suspension assembly. Those aren't typically included in the mechanic's sets sold at the box stores.
Air tools are your friend and having an impact gun and air ratchet makes life sooooo much easier, especially for a donor teardown. There are several bolts that can be difficult to remove without them - they spin nuts and bolts much faster than you can - like many of the suspension connections (struts, steering joints, ball joints, etc.).
I wonder where you got this idea from. :cool:
one of the biggest ones is a seat belt T50. There’s actually a special T50 for seat belts from Snap-On. its the T50OE. You’ll notice the the ends are not points, they are blunt cuts. This grabs the seat belt bolt much better and won’t strip them.
or electric equivalent ;)I have switched to Milwaukee M18 and M12 impacts, ratchets and such. I haven’t touched my air tools in a long time and don’t miss dragging an air line around.
I know that air tools have been the industry norm. With battery technology progressing, there are some good alternatives. I bought this wrench about a year ago. It is by far my go-to tool. I highly recommend it.
list item - good wobble socket extension
you beat me to the post!!!! :)
PyroGuy923
Here is what I've purchased thus far.
ItemQuantityCostTotalVendorStore
3-Ton Quick Rise Aluminum Floor Jack1$228.50$228.50Arcan
ARES 33pc Security Bit Set1$9.92$9.92ARES
70085-3/8-Inch Drive Aluminum Socket Organizer2$11.99$23.98ARES
70344-1/2-Inch Drive 9.84-Inch Aluminum Socket Rail1$9.99$9.99ARES
70149-3/8-Inch Drive Aluminum Socket Organizer2$9.99$19.98ARES
70084-1/4-Inch Drive Aluminum Socket Organizer3$11.92$35.76ARES
3" Impact Grade Socket Adapter/Extension Set1$7.99$7.99ARES
3-Ton Jack Stands1$24.94$24.94Big Red
2503MFRPH 1/2-Inch Drive Adjustable Micrometer Torque Wrench1$146.85$146.85CDI
927 8-Inch Snap Ring Plier1$23.51$23.51Channellock
8WCB 8-Inch WideAzz Adjustable Wrench1$25.41$25.41Channellock
MS8233D Auto-Ranging Digital Multimeter1$19.99$19.99Crenova
Screwdriver Bit Set, Impact Ready1$21.23$21.23Dewalt
DCF885B 20-Volt MAX Lithium Ion 1/4-Inch Impact Driver1$112.50$112.50Dewalt
20V MAX XR Impact Wrench Kit, 1/2-Inch (DCF899M1)1$249.00$249.00Dewalt
1/2-Inch Drive by 24" Length Breaker Bar1$19.87$19.87EPAuto
Gripper Wrench Organizer2$7.95$15.90Ernst Manufacturing
3/8" Drive Flex Head Ratchet1$47.99$47.99GearWrench
Micro Cutter1$7.95$7.95Hakko
MINI Needle File Set1$5.99$5.99Kalim Life Shop
10-Inch Cobra Pliers1$26.85$26.85Knipex
3-Piece 1/4-in; 3/8-in; 1/2-in to U-Joint1$24.48$24.48Kobalt
0288A Master Hex Bit Socket Set1$34.98$34.98Neiko
1/2-Inch Drive Shallow Impact Socket Set, Metric1$26.39$26.39Tekton
1/2-Inch Drive Shallow Impact Socket Set, Inch1$28.10$28.10Tekton
Precision Pick and Hook Set1$7.76$7.76Tekton
4971 1/2-Inch Drive Impact Extension Bar Set1$11.50$11.50Tekton
13-piece Torx Bit Socket Set T8-T601$14.99$14.99WORKPRO
6" Heavy Duty Utility Combination Pipe and Bench Vise1$124.07$124.07Yost Tools
Axle Nut Socket1$21.99$21.99Performance Tool
1 Ton Pittsburgh Automotive Folding Shop Crane1$139.99$139.99Pittsburgh Automotive
3/8 In. X 14 Ft. Grade 43 Towing Chain1$19.99$19.99Haul-Master
30 In X 18 In 1000 Lb. Capacity Hardwood Dolly2$15.99$31.98Haul-Master
Waste Oil Storage Container1$13.99$13.99Pittsburgh Automotive
4 pc Funnel Set1$1.24$1.24HFT
Brake Bleeder And Vacuum Pump Kit1$19.99$19.99Pittsburgh Automotive
3 Ton Steel Jack Stands1$24.99$24.99Pittsburgh Automotive
WLC200 80 Watt Soldering Station1$67.77$67.77Weller
ST Series Soldering Tips, Set of 5 Shapes1$12.95$12.95GeToo
12" Wonder Wrecking Bar1$8.97$8.97Stanley
Locking Plier Set, 3 pc.1$22.97$22.97Huskey
Center Snips1$13.97$13.97Milwaukee
7 in. Diagonal Cutting Pliers1$18.97$18.97Channellock
Another special tool. The rear brake calipers with a parking brake are a pain in the ass to bleed when you use a tube to catch the fluid, so I cut a cheapo 10mm wrench to get into those tight places.
dang! you just keep cutting up tools over there!!!...... :)
