Adam in CLE
Can anyone tell me why my half shafts point up? When the car is set on the ground they will go up even more. Very perplexed, any help is greatly appreciated.
Or unscrew the coilover body until it’s about 13.5” from the bottom mounting body to the top of the threads of the coilover.First, I am not a Goblin builder, so just some thoughts. @ JBINTX - Unscrew your shock to make it longer. Your ride height is wrong. The angle of the ball joint seems okay on the LCA. Take a level or carpenters square and measure from your front LCA to subframe attaching point to the ball joint -- try to get that level (or at least eyeball it). Loosen your spring perch, so you have no preload on the spring (it will spin freely and should be loose), then tighten the perch so the spring has no up/down movement (it may still spin with some resistance.) Tighten your perch one one to two more turns. See where you are compared to where you are now! Make fine tune adjustments.
Thanks!Are you asking about the toe rod being squared with the car and straight in line with the DF replacement for the rack? It runs at an angle.
That makes sense. If someone else said that, sorry I didn't get what was being stated. That part I didn't adjust. I installed as it was sent to me with the only adjustment being raising the bottom of the spring 4 inches up.you problem is 100% the shock portion of your coilover threaded too far into the the lower mount. You are not the first to do this. If you look at the bottom of the coilover it should have about 4.5 to 5 inches of open space. Go to the post gstorey linked and follow the setup.
