I thought the entire brake reservoir was a wide open container for the brakes and clutch. I was wrong. I noticed this while bleeding the clutch and before I knew it I was pumping air into the line and had to start all over with bleeding the clutch. While they share the same fluid, there is a separate compartment for the clutch fluid. In order for fluid to get into the clutch compartment, the level has to be as high as the molding mark, this is above the MIN level. The car also has to be level as does the mounting of the reservoir. You can inadvertently mount the reservoir on the lower two holes in the brake pedal box and this will cause it to be out of level and probably cause a lot of problems with fluid getting to the clutch. It needs to be mounted on the top two holes.
The red area is the clutch reservoir. The two black lines are the small slots that allow fluid in to the reservoir. Notice that they are at the top right at the molding mark.
This is the top section and again there are two slots for fluid to pass and it's right at the top.
You can see here that even with the fluid level this high, it's barely enough to keep the clutch reservoir full. During bleeding, this can cause the clutch reservoir to empty very quickly since there is so little capacity for it. Also notice this level is quite a ways above the MIN level.
I knew there was a reason to keep the old reservoir all this time. Now I can finally toss it in the trash.
