GoblinGuyZ
So a quick back story. Ordered a stage 2 kit from ZZP which includes injectors, smaller pulley and new re flashed PCM which confirmed by Ryan at ZZP they use HPTuners to flash. 2 weeks later installed the parts and got ECU error indicating I needed a crank relearn so I purchased the MPVI3 with 2 Credits from ZZP since this was the easiest way for me to get this done. After many attempts I was finally able to get the crank relearn done from inside the scanner. After a very quick drive I got a lean LT trim bank1 code so was told to send them a log to initiate a remote tune but first decided I want to increase the injector table a bit to make it a bit richer to be on the safe side before doing the log. So I downloaded the HP Tuners flashed file from the ECU and made the small edits to it. All the while everything connected great, scanner ran fine, I could read ECU information and I could download the map file from the ECU with no issues. After the small changes I made, I made sure I had good voltage on plug in power on laptop and all was good. I then clicked 'Write Calibration'. It did the first few connection checks etc and Erased the map then it got to the write stage, wrote 1% then stuck for a few seconds then I got a 'Writer Transfer: Timed Out' Error. I immediately then tried it again and as soon as it says Requesting Access I get a 'Controller Unlocker : Timed Out' error. Tried it several times, same error.
Engine will no longer start. I had the original ECU the donor engine came with as well there and figured it was probably something wrong with the ECU from ZZP itself maybe so tried it on my original one after of course having to purchase 2 more credits ($100 extra). Same exact issue. I have tried it no less than 150 times in the last couple of days since some people said they eventually got theirs to go through. Every 20 or so times it might get to the write phase but always times out, the farthest I have gotten is 57% but usually times out at 1% or sometimes before even getting to the write phase. I scoured the internet looking for a solution and it seems many persons have had this same problem but I have yet to find a working solution. I have tried....
New battery. Battery with charger attached, 3 Laptops with different windows version installed, 3 cables, all the different ports, 2 different internet connections, one LAN and another WIFI, disconnecting the battery for 5 minutes, 30 minutes, 1 hour, overnight. Removing every single non critical fuse from the vehicle, cleaning out the pins on the harness and the OBD2 port, resyncing the module several times, downloading the BETA software, making sure nothing else on the vehicle was on (fuses all removed anyway). Checked all the grounds over. Vehicle has no electric issues otherwise. I cannot even start my vehicle and am at my wits end. Of course I reached out to HP Tuners and even though this seems to be a common issue not once is it mentioned in their support tab so I opened a ticket. This was the response I received...
"I've looked over the info and have had a conversation with the engineers and at present this vehicle has been disabled from tuning, the engineers are working quickly to fix the issues at hand but unfortunately I do not have an eta on when this will be supported again I'm sorry." So I asked if they meant my specific vehicle or that model and was told "The issue is with the ECM type there were a couple of other flavors of ECM's that were affected and temporarily disabled them till everything gets fixed."
So I have two separate ECMs that are now bricked and one of them just a few days ago was written by ZZP with the same HP Tuners and Ryan tells me they are still writing to them daily. HP Tuners cannot explain that to me, their response to that..."Not sure how there doing that"
So right now I have a Goblin in my garage, great weather outside and all I can do is turn on the lights and look at it. My only option is to consider all of my upgrades wasted money ($2000 at this stage) including the HP Tuners module and all the credits, remove them and purchase a stock ECU and reinstall until HP Tuners can sort it all out even though there is no indication when or if that will ever actually happen and I am having a hard time believing it to even be the case if ZZP is still writing to them all now and they have no reason to lie to me. To say I am angry and frustrated is an understatement. I asked about at least refunding me my credits and that question has been ignored.
The way I see it if you have listed a car as supported and allow a user to use their credits on said supported ECU only to hear after that oh we aren't currently supporting that ECU then that is as close to fraud in my book as you can get away with and I'm pissed to say the least.
