williamj95
Rttoys maybe I'm blind, but I'm not seeing the answer to my question in the link you provided. That thread seems to be all about the brake lights.
Don't be confused by the LH/RH cast into the calipers - the LH goes on the right (passenger) side and the RH goes on the left (drivers) side. Just keep the bleeders on top and you'll be fine.Oh I see now. Those brackets are in the parking brake kit which I haven't starting messing with yet. Thanks for your help.
You don’t understand how the data wires work. It doesn’t work off a change in voltage but instead is sending data in packets that the individual modules know how to read. This happens way to fast for a voltmeter to really read and all you get is an average voltage but no way of knowing what the data actually says. That is why the wire diagrams show sections labeled “logic” since the modules are basically computers making decisions based upon what the data packets are telling them.Gtstorey, I found your chart. Here it is.
All my voltages line up with yours, except the white wire (pin 5). I'm getting 12V with the key in. 4V at Run. You didn't list a voltage for Start but I'm getting 3V. I gut tells me that the Start voltage should be 12V. As I said above, the voltage on the data wires coming out of the BCM doesn't change when the key goes from Run to Start, so it clearly isn't sending the correct signal to the ECM. It would be great if one of you all could put a voltmeter on the white ignition wire of your Goblin and tell me what the voltage is in the Start position. That would completely answer the question.
