Any 2 builders interest in a curved, low angle, polycarbonate windscreen?
I'm guessing $200 to 250 for a hardened, scratch resistant, UV protected polycarbonate windscreen,
some mounting hardware, and trim molding.
The green zone is always flopping in the wind, so I was thinking of bracing it from behind.
When I do, it also can be a mounting point for the polycarbonate.
The top corners will be secured with a
P clamp and a bolt.
The closest to the steering wheel is 4" away, so no issues knocking knuckles.
The curvy tape line shows how far down the hood that the clear polycarbonate would reach.
The top 1/3 of the hood is visible thru the windscreen.
If you want to try a cardboard template for your car, here is a starting layout.
Scale it so the dots inside the green circles are 18" apart,
and the dots in the red circles are 48" apart.
I am thinking about trimming at the purple lines so that it fits on a 60" piece of polycarbonate.
For the bottom section of the windshield, I was planning on using
this clear edge trim where it contacts the hood.
So this template is 29" high, and 60" wide.
This sheet would be big enough to make 3 windshields.
