I can check the service manual this evening if no one weighs in. Post a picture looking straight at the end of the connectors.
I believe your right that’s what I was thinking thanksThe connector with two wires and blue lock is likely 12V accessory. The 4-wire one I don't recall.
ThanksI have confirmed these with the service manual.
The four wire connector is “x307 body harness to a/T shift control module”. For any one looking at this later, that very similar connectors have several uses on the later models so you have to check the wire colors and actual connector color. Most are removed anyway but one is used on the turbo boost gauge.
The 2 wire is the “accessory power outlet-center console”.
