Dale E
All those grounds should have ended up at G-105 back of engine stud. I think some of you put your ground wires on a chassis bolt under or near the fuse box.
Put in the relay, but leave it up just a little and connect a ground jumper wire to the ground lug on the relay. This will bypass the normal wire and should start the engine. If it doesn't start the engine then start checking the fuse box plugs and pins for non contacting gaps or bent pins. All the videos I sent show the ground connection at G-105 (up to maybe four wires connected together into a single mounting connector to the back of the engine bolt near the oil cooler. There were a couple of other videos that showed other areas to cause a no start.
Recently someone found that same ground to be the cause. ARK-D had that ground as his issue - has a video of jumper wire fix on his build log.
Dang it!! I guess I'm going to have to build a Goblin so I can help you guys more.
Dale
Dale
