2.0 LSJ GEN 3 Engine Package $5000
RobC76
RobC76
LSJ Gen 3 Engine Package:
New Gen 3 LSJ block from ZZP
Block finish honed with torque plate and ARP head studs
Diamond Pistons 10.0:1
Molnar H Beam Rods with ARP 2000 Bolts
New GM Mains and Rod Bearings
New Rear Main Seal
6 Quarts of Comp Cams 10W – 30 Break in oil
Zinc Break in additive
2 - K&N Oil Filters
Wiseco 86MM Ring Compressor Sleeve
CAT V Ported and Rebuilt Head:
Inconel Intake Valves
Inconel Exhaust Valves
82# ZZP Springs
Titanium Retainers
New ZZP Rockers
New ZZP Lash Adjusters
New ARP Cam Cap Bolts
Head Gasket
Intake Gasket
Other Components:
OTTP Balance Shaft Delete
Water Pump Gasket Set
T Stat
Timing Chain and Components
ZZP Upgraded Timing Chain Guide Bolt
Upgraded Timing Chain Tensioner Bolt
Choice of Stage 2 ZZP Cams or
Stage 3 OTTP Cams
2 - New GM Non TTY Cam Sprocket Bolts
Powder Coated Valve Cover
ZZP Valve Cover Breather
New ZZP Valve Cover Gasket
Powder Coated Oil Pan
New Oil Pan Plug Seal
ZZP Oil Cooler Relocation Plate
Machined Front Cover
GM Front Cover Gasket
ATI Balancer (Overdrive)
All Parts are new other than the head core, powder coated, valve cover and oil pan.
Machine work was done at a local race engine shop by the owner of that shop.
RobC76
More Pics
RobC76
Thought I would include the prices of the parts just for reference.
Thanks
New Gen 3 LSJ block and LSJ Crank from ZZP $1750.00
Block finish honed with torque plate and ARP head studs $450.00
Rotating assembly balanced - included above
Piston pins fitted - included above
Diamond Pistons 10.0:1 $700.00
Molnar H Beam Rods with ARP 2000 Bolts $515.00
New GM Mains and Rod Bearings $120.00
New Rear Main Seal $20.00
6 Quarts of Comp Cams 10W – 30 Break in oil $60.00
Zinc Break in additive $9.00
2 - K&N Oil Filters $32.00
Wiseco 86MM Ring Compressor Sleeve $50.00
ARP head studs $160.00
Subtotal $3866.00
Cat V Labor $1,050
Inconel Intake Valves $220.00
Inconel Exhaust Valves $220.00
82# ZZP Springs $299.00
Titanium Retainers Included above
New ZZP Rockers $120.00
New ZZP Lash Adjusters $100.00
New ARP Cam Cap Bolts $75.00
Head Gasket Cometic $100.00
Intake Gasket $20.00
Subtotal $2204.00
Other Components:
OTTP Balance Shaft Delete $30.00
Water Pump Gasket Set $18.00
T Stat $12.00
Timing Chain and Components $125.00
ZZP Upgraded Timing Chain Guide Bolt $12.00
Upgraded Timing Chain Tensioner Bolt $40.00
ZZP Upgraded Timing Chain Guide $80.00
Choice of Stage 2 ZZP Cams or $650.00
Stage 3 OTTP Cams
2 - New GM Non TTY Cam Sprocket Bolts $12.00
Powder Coated Valve Cover $60.00
ZZP Valve Cover Breather $30.00
New ZZP Valve Cover Gasket $25.00
Powder Coated Oil Pan $60.00
New Oil Pan Plug Seal $3.00
ZZP Oil Cooler Relocation Plate $80.00
Machined Front Cover $240.00
GM Front Cover Gasket $30.00
ATI Balancer (Overdrive) $449.00
Subtotal $1956.00
Total $8026.00 not Including cores mentioned below.
RobC76
If anyone is interested in this with no head or cams just reach out and we can work something out.
Thanks
