Haven’t finished the build yet unfortunately. Life has it on the back burner at the moment. The kit comes with everything you’d need to remove the SC and put a TC on the LSJ. You retain the factory Laminova cores and intake, the kit comes with the new exhaust manifold, turbo, turbo oil lines, and intake tubing though. Otherwise, your goblin build proceeds just like the normal SC build. You’d still have to run the tubes down the middle to the heat exchanger in the front (or where ever you mount your heat exchanger) and run the heat exchanger coolant pump used in the factory SC setup.
