A Adam in CLE Well-Known Member A Adam in CLE Well-Known Member Aug 9, 2022 #1 Does anyone know the size of the frame boss that the lights would mount to? Looking for diameter and pitch.
G Gtstorey Goblin Guru G Gtstorey Goblin Guru Aug 9, 2022 #2 I think 3/8 and I’m sure a course thread. So that would be 3/8-16.
k.rollin Goblin Guru k.rollin Goblin Guru Aug 10, 2022 #3 3/8-16, per Lonny (see below): Nilbog's Matte Blaze 08 LT The ignition switch uses screws. I drilled mine all the way through and used a 1/4" bolt and nut. dfkitcar.com Unless you do like I did and re-tap them to suit your application (mine are M10-1.25).
