viperbmw69
Active Member
- viperbmw69 Active Member
Group I need some assistance. I am looking for a good Set of LED Headlights Do you guys have a recommendation? I need the Headlights to be four wire and apparently thats rare.
Also I need help understanding the wiring for a radio..... I have a headunit that says it needs "Constant Battery" But when I plug that into a wire Directly to the Battery and the Ground to the Ground post above the Pedal box. It blows the internal 15amp fuse in the Headunit. Can anyone help me understand why this is? I wired with a different wires to verify its not the wiring it still blows every time. Is there supposed to be a resistor in line or something? ???? Im confused......
