I'd rather have a magically refilling tank. I picked up the new Ryobi automotive high flow pressure washer kit and I can get my car nearly as clean as I like it to be faster than I can fill the tank. That's just me, though, I never got into figuring out why I can only dribble fuel into my car.
This new electric pressure washer really is the bees knees for my usage, which is primarily car washing. I've used better wands/guns and hoses and foam cannons, but for a single kit at only $150, it's hard to beat. Depending on how dirty my car is, I'll either just hit it with straight water, or a quick foam cannon over the hood and the exterior-most body, quick mitt, and an easy rinse.
I think I need to remove the baffle inside the fuel filler neck, but cutting a few minutes out of my fill-up will only deprive my pump neighbors from chit-chatting which I don't mind.
Clean itself. It’s a ginorus pita to wash (correctly). You see everything so everything has to be cleaned: inside wheels, suspension, engine, fuel tank, interior (that you can’t really get wet)…..everything.
