Goblin Professor
- Ross Goblin Professor
From AllDataDIY:
The bypass valve is controlled by a vacuum actuator which is connected to the vacuum signal between the throttle and the supercharger inlet. Spring force from the actuator holds the valve closed to create boost, and vacuum pulls the valve open when the throttle closes to decrease boost. The open bypass valve reduces pumping loss thereby increasing fuel efficiency.
The solenoid valve attached to the bypass actuator is an electronically controlled, 3-way valve. This valve, controlled by the powertrain control module (PCM), determines whether pressure from the manifold is routed to the bypass actuator or closed off. The valve allows pressure from the manifold to open the bypass valve and regulate boost pressure during specific driving conditions.
Supercharger boost pressure is regulated under certain conditions to prevent engine and drive train damage. When the engine is operating under high boost conditions, the powertrain control module (PCM) can limit boost pressure to 83 kPa (12 psi) or less. The PCM disables boost under the following conditions:
There is more.... but this is getting long.
- When reverse gear is selected
- When the vehicle is decelerating
- If an intercooler pump failure is detected
- If the intake air temperature (IAT) sensor 2 becomes excessively high
- If the engine coolant temperature (ECT) becomes excessively high
- Under heavy load in first and second gear at engine speeds above 5,800 RPM
- When drivetrain abuse is detected
