I have wondered about that myself. When I press the valve in only a few drops comes out. Even after the pump has primed and the line is pressurized.Okay added more fuel showing a 1/2 tank now. I took the fuel line off the fuel rail and put the end in a bucket the fuel pump primed a lot of fuel into the bucket I'd say a couple cups worth.
When the fuel pump is done priming I push the little fuel button on the fuel rail. Am I correct to expect that this should be under pressure? When I push it even right after the pump prime it just barely comes out maybe a couple drops then nothing at all. This is after the pump prime and with the key still in the run position.
Nuker-
what size wheels/tires are you using?
Not all fuel gauges will depress the Schrader valve. Are you sure it's being depressed? I'd remove it all together to make sure because depressing it all the way can also mess up your readings.Well I guess this would be a problem lol......
Now what the hell could be causing that out of nowhere. I think I'll go buy another new fuel filter and start there. The fuel pump and filter are both brand new not reused from the cobalt.
https://drive.google.com/open?id=0B70aLtzjTRE4bm92Ynh4Q05CdTQ
Nuker-
