Running something that small you'll be fine sticking with the 4 lug pattern. Just look for wheels for a mid 90's Miata and you should be all set!I’m not currently planning on real meaty tires, at the moment 205/55 ZR16
To be VERY honest Wheel size that will work without issues is my biggest concern.
‘Sorry but what dose “square set up” mean?
I was going to have a 245 rear section, but Maxxis didn't have them in stock when I ordered my tires.Same size tire and wheel specifications at all four corners. If the front wheels are 15”, the rear wheels are also 15”. Same thing with the tire dimensions, if front are 205/50, then the back tires are also 205/50.
Nice benefit for this is the ability to rotate wheels to even out tire wear patterns. However, most (if not all) manufacturer produced mid/rear engine cars run a staggered setup with narrower wheels/tires in the front compared to the back.
