Aftermarket Pedals
finazzoty
F
Has anyone looked into options for aftermarket pedals/pedal box? I can’t imagine it would be too difficult to make some small adjustments for this. But then again… “how hard could it be?” Dangerous words
a few have used aftermarket pedal boxes. Biggest hurdle is getting the sensors to mount in the right positions I believe. Otherwise mounting is straight forward: few holes to be drilled, some nuts/bolts/washers added and you're done (very simplified). You'd need to figure what size master cylinder to use as well, different reservoirs and their mounting locations (factory is a shared unit for clutch and brake), etc.
Tinkles
I had a decently thick section of flat steel welded into the driver-side footwell that I bolted a Wilwood floor mount pedal box to.
J
Do you have any pictures? Or better yet, the old clutch pedal assembly? I threw mine away on accident. I was also looking at the Wilwood floor mounted pedal
