ncgoblin
- ncgoblin Goblin Guru
Hey All,
I have purchased camber adjustment bolts to bring in my camber to -1.5 degrees the problem is back when I originally started my build I drilled out where the hub assembly connects to the suspension to increase hole size to bring in the camber this was a bad idea. Now that I have the proper bolts its nearly impossible to get the camber right and they do not even function properly because the hole is larger then the bolt. Is there any way to increase the hole size or am I looking at buying used bearing housings online?
