Kenny123
- Kenny123 Well-Known Member
- So I installed a new throwout bearing, clutch, pressure plate and flywheel. Got it all buttoned up and installed on the engine... engine installed in the goblin frame and getting ready to start bleeding. I then realize the throwout bearing must be full of air. The bleeder is above the transmission so my fear is that I need to have the trans and engine separated to get fluid through the bearing. Is there anyway to bleed the TOB without separating the trans and engine? I have a power bleeder setup however I don't see how that will get the air out of the TOB. THANKS GUYS.
