E85 requires about 30% more fuel:air than gasoline. So, yes you need injectors that can flow that much more fuel.
If your 09 SS has a flex fuel sensor, then the ECU is ready to run the new fuel, and your injectors will be sized to handle the extra fuel.
If not, you will need to tune the ECU to run on the new fuel, and have big enough injectors installed.
