People have tapped the tubes themselves. Like KS said, there’s not much to thread though. You’d still want a lock washer of some sort. I also used m4 rivnuts, small washer and lock washer as well.
I tapped the firewall and not really pleased with how it turned out. If I did it over, I would just use standard blind rivets. I'm not sure when that would need to come out again and simple enough to drill or grind rivets off.
I started down this path with my tunnel cover and had issues. After drilling out a screw I snapped the head off of I used rivets and it was so much easier.
I also used rivets on my hood plate and drilled those out when I sent my hood in for wrap. It wasn't that big of a deal - much less effort than tapping the tunnel and dealing with issues.
I just ordered a bunch if M4 rivnuts, button head bolts, lock washers and nylon washers. Going to try this method for the firewall, side panels and center console cap.
