Picture was not for hood mounting but shows enough. Hood plate is riveted or bolted to the fiberglass hood. Hood attached to chassis through the 2 allen head Dzus fasteners. Sorry that it is all black. Bottom plate not included in kit.
I put the metal strap on the inside based upon wanting the larger head of the rivet on the fiberglass and the expansion part of the rivet on the metal.
If you are concerned about pulling the rivets through, perhaps you can double plate it or use appropriate sized fender washers for better area coverage. One of my cars has the bonnet latches riveted with the latch being the outside plate and there is an inside plate about an inch square. It has been stable for 16 years.
I sandwiched the fiberglass between the factory metal bracket and a piece of aluminum I had lying around, using it like a skid/ware plate. If the rivet heads get worn off I can just replace as necessary.
