Improving performance
jennam
jennam
So I've been kicking around the idea of adding some ponies to my Goblin. Looking at the cost of some of the aftermarket performance parts, I'm starting to wonder if it might be cheaper/easier to find an SC or TC donor and harvest the engine/bcm/wiring/etc and do a transplant.
What do y'all think?
Karter2026
If you could find one for a steal it may be worth it.
Tinkles
Swapping the supercharger system onto an non boosted Ecotec is very simple and the M62 will not make enough power to hurt a stock engine(provided that the tune is good). I have done a few installs and it can be done in a weekend by yourself or 1 afternoon with a few helping hands.
Plus the N/A Ecotecs have a higher compression ratio than the boosted ones so it will allow you to make alittle more power.
My buddy put this together. It is for Cavaliers/Sunfires, but 85-90% of the info will be accurate for Cobalts/Goblins.
jennam
Another reason I'm leaning toward doing a transplant is I'd really like to get cruise control. I'd also like to pull up some additional 12v lines and pull the factory stereo power lines up to my new dash as well. I know I can pull some of those pins out of the BCM and run wires off of them, but that won't solve for the cruise thing.
Originally, I never thought I'd ever want cruise; however, after logging a few thousand miles this summer, I'm regretting that decision........
jennam
@Tinkles The swap is tempting too, however, I haven't seen a M62 sell for less than $600 recently by itself. One would need a number of other bits on top of the M62.
Tinkles
M62s are $200-$300 all day. $600 should get your a pretty complete kit. I paid $2k for my kit 10 years ago so prices have tanked. Jeff Reiland(Facebook) parts out Ecotecs all of the time and usually has most of the S/C swap parts in stock. Installing a M62 on your current engine will be the cheapest and easiest option. But I don't know about Cruise Control as I have never messed with a Cobalt PCM/BCM.
jennam
Interesting. I'm not having any luck finding them that cheap. they are $5-800 on ebay and the full kit from ZZP is $1700+
Tinkles
You still need the Idler pulley, belt tensioner, and alternator spacer bracket, but this is a good start.
That seller is Jeff Reiland. He is the go to for used Ecotec parts. Look through his inventory and see if there is a kit that you like.
jennam
You still need the Idler puller, belt tensioner, and alternator spacer bracket, but this is a good start.
Cool. I'll have to check that out.
Karter2026
I built a Idler pulley bracket for mine so I did not have to run the gutted A/C compressor. And just running a 5 rib belt so I did not have to change alternator and crank pulley.
