I bought this kit that has a wide assortment. Figured some may benefit from the smaller ones (tunnel or rear firewall) where there won’t be much tearing force from wind, but the side panels could use something larger. Also bought these weld tabs for the side panels that I’ll put the rivnuts in
SKU AA-023-D – Body Tab, 1/8" Steel, 1/4" Hole, 1 1/2" Tall, 1" Wide (Flat Bottom), 15/16" From Center of Hole to Bottom of Part, Formed | A&A Manufacturing
www.aa-mfg.com
I am doing the same thing but will put a nylock nut on instead of a rivetnut
So 1/4-20 on the side panels and 10-24 on the tunnel.
www.aa-mfg.com
Or make your own tabs out of 1x1/8 steel strapping which can be purchased tjat has 1/4 inch holes drilled - or buy solid and drill your own if that's your thing - and cut to whatever size you need with a saw/grinder.
I usually try to use 5mm at minimum. I found that the smaller ones dont get very good thread bite and tend to strip the mandrel in short time. Also, stay away from aluminum rivnuts.
