V1 Run Flat Tires
For street driving run flats are okay, but they are very stiff and have somewhat higher tread wear. Edit: TW about 300 is what most run flats are rated, far too hard tread for a Goblin. If you plan to do anything on track - autocross - not recommended.
I'm going to keep a flat fix kit in the goblin just in case. I'm wiring in USBs and a 12v plug so I can run an inflator when needed.
