KingChuck24
- KingChuck24 Well-Known Member
Just needed some help identifying lines that run to one another:
Does the line from the valve cover run to the overflow tank?
Does the nipple coming from right above the coolant return line go to the port right next to the MAS on the intake?
I know one of these goes to the clutch master cylinder, which one is it? Where does the other one go to that doesn't go to the clutch master cylinder?
Thanks!
Thanks!
