Here's a compilation of torque values from the videos plus a few things I had to look up in my service manual:
Accelerator position sensor-to-brake bracket 80 lb-in
Brake booster-to-pedal box nuts 14 lb-ft
Brake pedal pushrod nut 89 lb-in
Chassis-to-engine mount bolt 48 lb-ft
Chassis-to-transmission mount bolts 48 lb-ft
Clutch pedal pivot nut 89 lb-in
Clutch pedal bracket nuts 89 lb-in
Rear control arm bolts 41 lb-ft
Front transmission mount-to-engine bolt 66 lb-ft
Front transmission mount-to-subframe through bolt 74 lb-ft
Horn bracket bolt 89 lb-in
Master cylinder-to-brake booster nuts 18 lb-ft
Pedal box bolts 18 lb-ft
Positive battery cable-to-fuse block 13 lb-ft
Positive battery cable-to-starter solenoid 13 lb-ft
Power steering bracket-to-frame bolts 44 lb-ft
Rear control arm-to-frame bolts 100 lb-ft
Rear transmission mount-to-subframe bolt 44 lb-ft
Rear transmission mount-to-subframe through bolt 74 lb-ft
Steering rack bolts 81 lb-ft
Upper/lower front control arm bolts 90 lb-ft
Upper/lower front shock bolts 30 lb-ft
Rod end mounting plate bolts 33 lb-ft
Steering arm bolts 33 lb-ft
Upper/lower rod end bolts 100 lb-ft
Tie rod nut 50 lb-ft
Bearing hub nuts 50 lb-ft
Brake caliper bracket bolts 85 lb-ft
Brake caliper guide pin bolts 25 lb-ft
Brake caliper banjo bolt 35 lb-ft
Exhaust pipe nut 37 lb-ft
Steering knuckle to rear bearing hub bolts 85 lb-ft
Steering wheel nut 30 lb-ft
Lower shock mount to steering knuckle bolts 89 lb-ft
Steering knuckle ball stud pinch bolt and nut 37 lb-ft
Brake caliper bleeder valve 97 lb-in
Wheel drive shaft nut (CV Axle nut) 159 lb-ft
Wheel lug nuts 100 lb-ft
