RobC76
- RobC76 Well-Known Member
LSJ Gen 3 Engine Package:
New Gen 3 LSJ block from ZZP
Block finish honed with torque plate and ARP head studs
Diamond Pistons 10.0:1
Molnar H Beam Rods with ARP 2000 Bolts
New GM Mains and Rod Bearings
New Rear Main Seal
6 Quarts of Comp Cams 10W – 30 Break in oil
Zinc Break in additive
2 - K&N Oil Filters
Wiseco 86MM Ring Compressor Sleeve
CAT V Ported and Rebuilt Head:
Inconel Intake Valves
Inconel Exhaust Valves
82# ZZP Springs
Titanium Retainers
New ZZP Rockers
New ZZP Lash Adjusters
New ARP Cam Cap Bolts
Head Gasket
Intake Gasket
Other Components:
OTTP Balance Shaft Delete
Water Pump Gasket Set
T Stat
Timing Chain and Components
ZZP Upgraded Timing Chain Guide Bolt
Upgraded Timing Chain Tensioner Bolt
Choice of Stage 2 ZZP Cams or
Stage 3 OTTP Cams
2 - New GM Non TTY Cam Sprocket Bolts
Powder Coated Valve Cover
ZZP Valve Cover Breather
New ZZP Valve Cover Gasket
Powder Coated Oil Pan
New Oil Pan Plug Seal
ZZP Oil Cooler Relocation Plate
Machined Front Cover
GM Front Cover Gasket
ATI Balancer (Overdrive)
All Parts are new other than the head core, powder coated, valve cover and oil pan.
Machine work was done at a local race engine shop by the owner of that shop.
New Rear Main Seal
2 - K&N Oil Filters
82# ZZP Springs
Titanium Retainers
New ZZP Rockers
Head Gasket
Intake Gasket
Other Components:
T Stat
Stage 3 OTTP Cams
