V1 Battery current sensor
finazzoty
F
Hi all,
I’m in the process of getting the remainder of the harness plugged in, and I do not see a connector for the battery current sensor as mentioned in one of the older build videos - side note, DF did my harness, so I’m fairly certain this would be here if it was needed. Should I proceed without this and just connect the main ground from the battery to the chassis without the current sensor? Quite honestly, I don’t even recall seeing a current sensor when I was pulling the harness out of the car, so maybe this is a non issue
UPDATE: Got a response from Lonny on this - for anyone else who may run into this issue, only the base model has a current sensor.
