TheNuker
- TheNuker Goblin Guru
I would like to replace the 2 rear brake fittings as they are leaking and no matter how many times I crank them down they just seep, If I cut just the tiny little flared part off and use a bubble flare tool to put a new flare in after replacing the fitting is this a problem?
Is the tube size 3/16? What is the nut size M10-1.0?
Would these work https://www.amazon.com/Stainless-Me...10+bubble+brake+fitting&qid=1622047018&sr=8-4
@Lonny
Thank you,
Nuker-
Amazon.com: OTC 6504 Deluxe ISO Bubble Flaring Tool Set with Cutter: Automotive
Buy OTC 6504 Deluxe ISO Bubble Flaring Tool Set with Cutter: Brake Flaring Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
@Lonny
Thank you,
Nuker-
