Mk7 vs. Mk7.5 — What’s the Difference?
Volkswagen refreshed the Mk7 Golf lineup in 2018, often referred to as the Mk7.5.
1. Golf 1.8T TSI (2015–2018)
What to avoid
- The chassis, engines, and transmissions stayed mostly the same, so both generations are fully compatible with the Goblin V2.
- Most differences are cosmetic: updated bumpers, lights, and infotainment systems.
- Minor changes to tunes increased stock horsepower for some trims but aftermarket tunes bring Mk7 and Mk7.5 engines to the same level.
- The DSG was updated from a 6 speed to a 7 speed. Good for economy but won't make a big difference in performance.
- For donor purposes, you can treat them interchangeably.
- Found in the base Golf trim (2015–2018).
- EA888 Gen 3 1.8 liter engine, IS12 turbocharger, rated at ~170–184 hp.
- Torque converter automatic or 5 speed manual
- Often the cheapest option on the used or salvage market.
- Responds well to tuning. A simple ECU flash can push power close to GTI levels or IS12 can be swapped out for an IS20 for more power.
- Great for builders who want a budget-friendly donor with room to grow.
- Performance model of the FWD Golf.
- EA888 Gen 3 2.0 liter engine, IS20 turbocharger, rated at ~210–230 hp depending on year/trim.
- DSG dual clutch automatic or 6 speed manual
- Widely supported in the aftermarket. Stage 2 tune easily unlocks 300+ hp.
- Best for builders who want a fast Goblin right out of the gate.
What to avoid
- Golf R / any AWD (4Motion) Golf - Bevel box for rear drive will need to be deleted for use in the Goblin V2 chassis. Stick with FWD donors.
