dastrups Well-Known Member dastrups Well-Known Member Mar 3, 2021 #1 Does anyone know if the engine mount bracket from the 05-07 SS will fit the 08-10 SS? Included a picture. Attachments 5D2C04F2-A939-44E0-9BF5-E2D24C92865F.jpeg 431.5 KB · Views: 368
G Gtstorey Goblin Guru G Gtstorey Goblin Guru Mar 3, 2021 #2 Online GM part site shows the same part #.
dastrups Well-Known Member dastrups Well-Known Member Mar 3, 2021 #4 So for the SS/TC do we only need this bracket and the supplied transmission mount spacers and bolts and that’s it?
G Gtstorey Goblin Guru G Gtstorey Goblin Guru Mar 3, 2021 #5 You also need GM part # 25827450 and it depends on when you ordered your kit or what options you selected for the lower mounts.
dastrups Well-Known Member dastrups Well-Known Member Mar 3, 2021 #6 Gtstorey said: You also need GM part # 25827450 and it depends on when you ordered your kit or what options you selected for the lower mounts. Click to expand... I ordered last October and I also ordered the solid transmission mounts from DF. Do you think I will still need the GM part #25827450?
G Gtstorey Goblin Guru G Gtstorey Goblin Guru Mar 3, 2021 #7 Yes you need the other top transmission mount. The DF solid mount are the lower mounts.
dastrups Well-Known Member dastrups Well-Known Member Mar 3, 2021 #8 Gtstorey said: Yes you need the other top transmission mount. The DF solid mount are the lower mounts. Click to expand... Thank you!!
Ark :D Goblin Guru Ark :D Goblin Guru Mar 3, 2021 #9 dastrups said: Thank you!! Click to expand... Make sure you order that top transmission mount WELL before you actually need it. I had a hell of a time getting mine.
G Gtstorey Goblin Guru G Gtstorey Goblin Guru Mar 3, 2021 #10 Yes. It shows as discontinued on a couple of the sites I checked.
