- bradr Well-Known Member
I could never find any info on the forums about the interconnect between the engine and body harness. All the "Non-GM" wiring diagrams only show a high level diagram, and not any of the intermediate interconnects. Some cars have a 14 pin and some a 16 pin connector (my 2010 SS/TC). Below is the info from my car.
Please note, Delphi connectors with letter designations for the pins do not use "I", "O" or "Q" as these might be confused with the numbers "0" and "1". Two corners will be marked with letters for reference. In the case of this 16 pin connector, "A" and "H" are marked. From the mating side of the connector, they are numbered left to right, top to bottom.
| Interconnect A | PCM X2 Pin 7 | Gray/White | HO2 (2) |
| Interconnect B | BODY HARNESS | Brown/White | MIL Lamp |
| Interconnect C | PCM X2 Pin 46 | Dk Green | Fan 1 relay control |
| Interconnect D | BODY HARNESS | Tan | Boost Signal Output |
| Interconnect E | PCM X2 Pin 33 | Gray | AC Pressure 5v Ref |
| Interconnect F | PCM X2 Pin 11 | Tan | AC Pressure 0v Ref |
| Interconnect G | PCM X2 Pin 39 | Orange/Black | AC Pressure Signal |
| Interconnect H | PCM X2 Pin 1|2|4 | Black/White | Ground |
| Interconnect J | BODY HARNESS | Lt Green | Reverse Light Output |
| Interconnect K | PCM X2 Pin 50 | Lt Blue | IAT Signal |
| Interconnect L | PCM X2 Pin 22 | Tan | IAT 0v Ref |
| Interconnect M | PCM X2 Pin 40 | Violet | VSS Low |
| Interconnect N | PCM X2 Pin 53 | Yellow | VSS High |
| Interconnect P | PCM X2 Pin 23 | Tan/White | HO2 (2) |
| Interconnect R | PCM X2 Pin 38 | Violet | HO2 (2) |
| Interconnect S | PCM X2 Pin 13 | Yellow | MAF Signal |
