JeffsGoblin
- JeffsGoblin Goblin Guru
Besides the AC and the two fan connections, what else can be removed from the engine harness?
What do you mean by the primary fan wire? I already pulled the two electric fan connections since I thought they weren't used back in the engine area.Not much else. The small connector that goes to the purge solenoid can go. You will want to keep the primary fan wire, it will get extended to the front.
What is this connection for and can I pull it from the engine wiring harness? I thought it was for the AC line.
View attachment 8383View attachment 8384
Thank you for the response! My fan setup wasn’t like that since I have the SS/SC, but I understand what is needed. I did pull the pin and of course didn’t take a picture.
