V1 Fender Kit?
i called 2 times, left 2 messages. no return call yet.
You're just going to have to be patient and keep trying.
I know that's not an ideal answer, but DF has been trending this direction for the last few years. On top of that, Adam and his wife had a baby recently and DF is a very compact operation to begin with. I'm not excusing it; if I were considering building today, it would probably be enough to turn me away.
The one thing I'm sure of though is, DF always takes care of you in the end.
F
ok
I recall the wide fenders were made for 225 and 245 width tires - 275 width would also be a great option too. This would cover 80% of the Goblins (very likely) who may want fenders - either from local registration requirements or for esthetics.
LaunchPad
well on my stalker fronts I tied into the "hub" by welding some connectors to allow the fenders to be removable. For the goblin you could tie into some of the many bolts and work from there. the organic type shapes turned out VERY difficult to do while on the car itself. and ended up with lots and lots and lots of re-welding then grinding and even starting over several times. . . this is one of the early attempts. YUCK
52614
in the end it worked out ok but could still use more cleanup work- maybe when i finally paint the headlight brackets? lol
52615
for rears you could do something similar to what i did for my wings. . . .a lil clamp on type of subframe
Amazon.com: BZBMGMO Split Collar Tube Clamps,UTV Universal Connector Weldable Tube Clamps, Long Connector Tube Clamp 1-1/4" Qty 4 : Automotive
52616
