ncgoblin
- ncgoblin Goblin Guru
I am doing some research and apparently you cannot utilize gas line, or heater hose for a brake resevoir hose. What are you all using for hose between the resevoir and the clutch pedal cylinder? Also the clutch has a shaft that just slides into the cylinder is there any seal? Trying to figure out if the fluid will leak out.
Thanks
Thanks
