Intermediate axle shaft
Zoom Zoom
Zoom Zoom
Don’t they make a longer shaft that does away with the intermediate axle shaft bearing and housing?
Sense it’s about impossible to find a replacement housing.
A Base model NA uses a one piece shaft on the passenger side. It directly connects the transmission output to the wheel hub. This axle is far weaker than the 2 piece axle used in the SS. But keep in mind this configuration also transmits torque 'steer' - in the FWD application - and I'm not certain how it would respond in the rear drive of the Goblin.
TheNuker
If you already have the intermediate axle, all of the parts should be available to rebuild it. If I can dig up the link to the bearings I'll post it here.
Nuker-
Zoom Zoom
Nuker-
I was trying to help another person out, I rebuilt mine already but he jacked up all the pieces on his including the intermediate shaft housing.
I suggested he check with Jefferey Reiland on Facebook
Our second Goblin was a base manual that had a long passenger side axle. Without looking at you would never know it had a long axle.
Even when Adam autocrossed his base manual Cobalt it did not have any odd steering tendencies. It did squeal those skinny stock tires through every turn though.
Would a base manual passenger side long axle fit on a Goblin that had the intermdiate driveshaft?
WYGoblin
Yeah I was scoping it out too. If no one bought it I was to have either as a spare or if someone needed it. They are getting hard to find
I think the transmission side of the F23 and F35 axles are different. If you could put the passenger side F35 stub on the long base manual trans axle then it would probably work.
Zoom Zoom
