KLMOTORSPORTS
- KLMOTORSPORTS Well-Known Member
SC builders....at what RPM does your boost kick in? I am getting no boost even around 3-4K RPM and wondering what could be wrong. Checked the Bypass with a vacuum gauge and it holds steady vacuum and the arm moves free, so presume the bypass is working right.
My boost gauge (Autometer) is run off the vacuum line from the intake (on top of intake when looking down between SC and Valve Cover). I am running an aftermarket engine harness, but don’t believe that should have an effect on showing no boost....any ideas?
Thanks!
Thanks!
