SOLD Harrop TVS 1320 Supercharger / $2,800 Shipped
RobC76
RobC76
Bought New from OTTP and never used. Has not been out of case. If it's listed its available. Thanks
OTTP Description: The Harrop HTV (Harrop Twin Vortices) supercharger system is a Roots-type supercharger manufactured utilizing the latest Eaton TVS ™ rotating assembly. Built specifically for GM's 2.0lt LSJ engines as a direct bolt on replacement for the Eaton M62 unit, It increases the Volumetric flow from 1.0 to 1.3 lt. per revolution which results in increases in both torque and power. The Harrop HTV supercharger's design features patented four-lobe rotors with high-flow inlet and outlet ports that greatly enhance thermal efficiency, delivering higher volumetric capacity, and enable higher operating speeds. The HTV supercharger is capable of running with a high efficiency across a very wide operating range. The four-lobe rotors feature 160-degree twists, the higher helix angle of the rotors coupled with redesigned inlet and outlet ports, improve the HTV's air-handling characteristics without increasing the overall size of the unit. The new Harrop HTV sets a new standard of supercharger performance and reaffirms Harrop and Eaton's leadership in the performance automotive market. Key Features Greater volumetric efficiency enables the rotating group to flow more air per revolution larger intake area which creates less turbulence and allows more air into the rotor ports Superior design creates less heat which equates to greater power levels High-Flow inlet and outlet ports that greatly enhance overall efficiency Less parasitic loss which takes less power to drive Quiet operation with a stealth appearance Thermal efficiency that exceeds 70% A 2.4 pressure ratio capability 1320 cc/rev - 80 ci/rev
RobC76
I have a bunch of ecotec parts on facebook market place, below is one of the listings and I think you can see all my listings from there if you care to browse.
Thanks Everyone
