RobC76
- RobC76 Well-Known Member
Assembled according to the DF assembly videos. Runs and drive very well.
If you have any questions just reach out.
Thank You
Rob Cleary / 989-239-2777
New Parts List:
New LDK / Turbo complete running crate engine
Nothing modified on engine other than ZZP stage 1 map sensors
GM performance stage 1 tune
New GM engine side harness
New Trans F35 / LSD (Purchased from DF kit car)
Standard length chassis
Dual door bars / easy entry
Dual roof bars
All stages of kit including Intercooler components
Hood / footwell cover / side panels / Windshield
NACA Ducts in hood
Headlight Kit
LED taillights
License plate kit
Side mirror kit
Rear wing mounts
Boost gauge
3-piece tunnel cover
DF Billet shifter
Corbeau seats and harnesses - 1 medium and 1 regular width
Racing struts and QA1 springs
Brake proportioning valve kit
Parking brake kit
Turbo exhaust
5x114.3 Hubs
ZZP 4 bar map sensors
OTTP axles
4DTech ABS Emulator
Working tire pressure monitoring
BCM programmed to zero miles at time of build
AN Braided lines - reservoir to brake master
AN Braided lines from fuel pump to filter to fuel rail
Replaced plastic intercooler fittings with brass
NRG Quick release wood grain steering wheel
Aluminum pedal plates
MOOG greaseable link bars
Upgraded Heim Joints
Bar Mounted rear view mirror
Steering rack
Steering shaft
Brake booster
Brake reservoir
Clutch master cylinder
Control arms and bushings
Coolant reservoir
Fuel pump module and fuel pump
Electronic throttle
Belt, hoses, lines
Clutch and brake switches
Multiple sensors, the only used sensors are the ambient air and light sensor
2025 Mustang GT wheels and Continental tires - New Takeoffs
Front and Rear 255 / 40 R19
Used from Donor:
ECM / BCM
Main harness / reworked
Electrical fuse box / cover
Ignition switch
Subframe - blasted and painted
Pedal box, pedals - blasted and painted
Rear knuckles (uprights) - bead blasted and painted
Some misc. bolts and hardware
Things to Finish:
Install side panels
Rivet or velcro front NACA ducts in after wrapping or painting hood
Parking brake cables and handle installed (All parts included)
Have inspected for registration in your state (Have factory MSO)
Pictures in following post
Thank You
New Parts List:
Dual roof bars
NACA Ducts in hood
Headlight Kit
LED taillights
License plate kit
Side mirror kit
Rear wing mounts
Boost gauge
DF Billet shifter
Parking brake kit
Turbo exhaust
5x114.3 Hubs
OTTP axles
4DTech ABS Emulator
Steering rack
Steering shaft
Brake booster
Brake reservoir
Coolant reservoir
Electronic throttle
Belt, hoses, lines
Used from Donor:
ECM / BCM
Ignition switch
Things to Finish:
Install side panels
