V1 Spherical upper strut mount group buy
*Prospective buyers only* What coilover are you running, and what type of mount do you want?
  • Koni coilovers on coaxial mount
    Votes: 0 0.0%
  • I'm interested, but I'm not running BC or Koni
    Votes: 0 0.0%
  • Total voters
    9
  • Poll closed .
duthehustle93
duthehustle93
Hi All,
It seems that several people who are running coilovers have snapped the top of their damper off. A McPherson setup uses the damper as a suspension member, so this failure mode can be dangerous if it happens on track, or at a high speed. Since the lower control arm moves on an arc, the top of the damper should be free to pivot... OEM's solve this by isolating the top of the damper shaft from the body with a bushing, and performance aftermarket typically opts for a spherical mount/coaxial mount/pillowball mount. Cyclic bending loads, a large stress riser at either the thread root or damper shoulder, and a hardened and hollow damper shaft all contribute to this failure.
I have a plan to make a one-off on a bridgeport for me, but I was debating designing something nicer and having a large batch made. If there's enough interest (~10 sets would be the minimum to where it starts to get cheap enough to manufacture) I can start polishing off the design for manufacturing. This will be a bolt-in solution that replaces the black anodized aluminum plate shown in the picture.
This will only apply to people running coilovers, or sleeved dampers. Sorry, I don't think this issue happens as often (if ever?) to people with stock dampers, and the design I have mocked up works better with standard 2.5" coilover springs. Final design and prototypes will be posted up before asking for any money.
The primary benefit of this is not snapping damper shafts. The secondary benefit is a reduction in binding and friction induced within the damper. This will have some performance and longevity benefits to the damper, although it may not be significant enough to be noticeable.
Options:
  • Standard spherical mount: spherical mount for the damper w/ integrated spring perch. This will get rid of the parts hamburger that you stack for the spring perch, as the perch will be integrated into the plate. The new plate will have a pocket in the center of the spring that accepts a replaceable spherical bearing that the damper will bolt to. Initial group buy pricing is $250 per set shipped (includes 2x anodized plates, 2x spherical bearings, and any required additional hardware).
  • coaxial mount. This will use the DF supplied strut spacer and spring perch. This mount will place both the spring and damper shaft on the spherical bearing, holding the spring and damper coaxial. The advantage of this is the spring won't banana at all, resulting in a slightly more linear spring rate. The downside is that the spherical bearing may wear out faster, and it's going to take me more time to develop this. If I'm honest, there is some performance gain with coaxial mounts, but it's marginal in my experience. ~$350 per set shipped (includes 2x anodized plates, 2x spherical bearings, and any required additional hardware).
  • additional camber option: I'm assuming most of you are running crash bolts, eccentric bolts, or are slotted. I'm also assuming that most of you are near or at the top of your adjustment range, I certainly am. I am considering moving the mount point inboard to increase negative camber, if that's something that people need.
In the interest of keeping costs down, and since this is something I'm doing on the side, I'll only be producing one design (whatever develops the most amount of interest).
____________________________________________________________________________________________________
Current status: I'm in process of setting up a second smaller batch. Group buy pricing is over, and I don't get the same bulk discounting for this batch, so pricing will be $295/kit shipped. If you are interested, please PM me. This will be the last batch of these made.
Design
Timeline
Install instructions
STL's/spare parts/documents
BC standard mount 0° offset:
  1. Gtstorey (paid)
  2. Comegetjoe (paid)
  3. Jaredthenav (paid)
  4. SmsDetroit (paid)
  5. Rttoys (paid)-
  6. Markm (paid)
  7. Indy Lonnie (paid)-
  8. OptimizePrime (paid)
  9. Sparvy (paid)
  10. WYGoblin (paid)
  11. ToxicBill (paid)
  12. KSLunsfo (paid)
  13. Meansol (paid)
  14. [me] *modified for 14mm shaft*
  15. 95Blitz (paid)
  16. David (paid)
  17. Stretch2126 (paid)
  18. gofast (paid)
  19. GearHeadzGarage (paid)
  20. Owenmachine (paid)
  21. RobC76 (paid)
  22. Keckster (paid)
  23. Jason d (paid)
_____________________________________________________________________________________________________
This project has been more of a passion project than anything; after assembly time it’s basically break-even. A lot of care has gone into the design, including FEA and validation of the hardware, bearings, and fits with a target FOS > 3 under a 3G bump scenario.
That said, as with any performance-oriented suspension component, I want to be clear about intended use and responsibility:
  • These parts are intended for off-road, racing, or competition use only
  • Installation and use inherently involve risk
  • Proper installation (including correct torque and hardware) is critical
  • The end user assumes responsibility for installation, use, and ongoing inspection
Great idea and it will increase the safety factor to help prohibit breaking the upper strut my mount. Since you are asking about having added camber, what would it take to actually make the camber adjustable (2-3 degrees) with some kind of camber plate? That would be the bee's knees! Just a thought... :D
I’m in for the $250 option but not it if it forces more negative camber. With aftermarket suspension bushings you don’t need much camber at all in a very light car. I need to push mine more toward zero from the current negative I was able to get with the additional slotting I did.
duthehustle93
Thanks! I'm trying to stick to a simple affordable solution. Since our upper shock mount is cantilever, I'd need to put a lot of testing onto a camber plate design to feel comfortable with other people using it... and most likely it would be more expensive than most people would want to spend in consideration of the already existing camber adjustment options for McPherson struts.
Copy! I'll put you down for a standard @ -0°. BC coilovers? Alignment is pretty application dependent, but I copied Justin Reed's setup sheet as a baseline with -2.6° of rear camber. I haven't gathered pyrometer data yet, but it appears to be a good starting point so far, at least for my application.
Im with this guy, if you're providing EVERYTHING needed as a package.
Copy, another vote for standard @ -0°. BC coilovers? Yes, this will be bolt in with all the hardware you need.
Sparvy
I'd be into a BC coax setup with 1°. Anything more than 1° and my tire temps on track are uneven across.
Copy! I'll put you down for a standard @ -0°. BC coilovers? Alignment is pretty application dependent, but I copied Justin Reed's setup sheet as a baseline with -2.6° of rear camber. I haven't gathered a lot of pyrometer data yet, but it appears to be a good starting point so far, at least for my application.
I'm sure that Justin needs more camber than most, especially on slicks. I wonder what his exact setup was when he was running -2.5. I’m sure he likely experiments all of the time with various settings.
duthehustle93
Got it! I'll put you down for that. Just to clarify, this would be an additional -1° offset to whatever you currently have.
I would also be interested in the standard BC spherical, 0°. Thanks for doing the work on this!
Copy, I'll put you down for that! Absolutely, thanks for the interest!
I’d be in for standard BC. I have the tubular subframe so I have camber adjustment there
Great, I've got you down for a standard BC... 0°?
Pierre,
You car deserves its own classified advertisement.
Did you know you put it in
Classifieds, Under the thread: V1 Spherical upper strut mount: potential group buy
This has nothing to do with this thread.
