grantcropper
- grantcropper Active Member
The donor I bought was in great shape and shifted nicely in all gears before we disassembled everything. Now that our kit is fully assembled, all the gears shift nicely except for reverse. When I try manually at the transmission with the cables off and I push on the shifter arms by hand to shift into each gear, all is good, just no reverse. Can someone confirm what direction each should be going to get to reverse? Also, what could have happened from donor to kit to cause this issue? When I try to get to reverse, it won't even pretend like its gonna go, just hitting a wall. Thanks for the help, y'all.
