Scott #321
- Scott #321 Well-Known Member
thanks Gtstorey I'm willing to try almost anything at this point.I disabled DTC P0234 and Engine Diag>Airflow>Overboost/Underboost>Enable RPM to max value (10,200rpm) in both columns.
You might could adjust Overboost Error, but I don't know how it works above the 120kpa column.
I’ve never been able to pick out the particular cause on a log. There are so many tables in the ECM that we don’t have access to that it’s just something to work around by basically telling the ECM to ignore it.here is a log file when it happens.
