V1 Wiring harness question
Hey guys, I received my wiring harness yesterday from the good folks at DF. I have 3 extra connectors up front and I just can’t seem to locate their plugs. Any help will be appreciated. The first one is down by the BCM. The other two are up by the steering column.
CaptFrank2001
1.) OBDII connector [for aftermarket OBDII reader] 2.) Looks like ignition Switch [need a better picture] 3.) Ambient Light sensor
k.rollin
The Cobalt came equipped with automatic lights, and I think I saw something about not having the ambient light sensor causing erratic behavior with the lights. Could be mistaken though.
RouteAbel
The first large one is your ODB2 port. It doesn't plug into anything and is a port to plug a code scanner in.
The second
The third is the ambient light
Yes, that's your TPMS/keyfob sensor. If you don't have TPMS, then it's only for the keyfob.
Is that required?
